Beovision 6 26 Pincode menu not showing
I received this TV for free with a few speakers I bought and I think I have some use for it. But to find out, I first need to know how to make use of it. The forums and the manual do not help me unfortunatly, so maybe I can make use of your knowledge. pincode There is a pincode set on the TV. I have succesfully used the temp masterpin 11111 to get into the TV. But unfortunatly I cannot enter the menu option to deactivate the users pin. According to the manual it is: Menu < < and then stop. The menu shows and after pressing < twice and then stop, I am back at the snow of television and no menu for a pincode shows up. What am I doing wrong here? Scart I want to make use of the SCART ports on the back. I have 3 B&O CRT televisions. They have the tuning option in the menu, but the 6 26 does not have that. Is that maybe because of the pincode issue I mentioned above? How do I choose one of the AV sources to be shown on television? I hope somebody has the time to help me out.
Try pressing menu twice in the sequence. If I remember correctly you have to be in the menu before doing what the manual says Regarding scarts you have to assign a source (V.tape/DVD etc.) in the connection menu
Thanks. Unfortunatly it doesn't solve the pin situation. Right after clicking STOP I am at the snowscreen again. I am missing the tuning option in the menu. On the other TV's I programmed the AV under the channel numbers. I did select DECORDER under connections for AV1 and AV2, but can't program them while missing TUNING. But maybe that has to do with the PIN situation? EDIT: I solved this by going into the TV with the Master Code 11111 and then with 0 0 and go to enter the system menu and reset to factory settings. Strangely I got back the option for TUNING.
