Beovision 11 55
Hi all
i have vertical lines on both sides of the screen any advice would be appreciated
col
There is a service manual for the Beovision 11-55 in the technical section of Beoworld that explains how to disassemble the set. The B&O service procedure is to replace the entire LCD panel if the LED strips are defective.
Good luck,
Jean
Hi Jean
yeah I have a few vertical lines, I have looked at the service manual it looks doable, but do we know make and model of the panel?
kind regards
col
Vertical lines ? Then it is not the backlight system . It may be the video engine or the T-Con board. The service manual has fault finding flowcharts.
But, can B&O service the set ? If spare parts are still available, then it is the solution, although possibly expensive.
Good luck,
Jean
Its a Samsung panel and as far as I have heard there is no panels available as spares.
I guess these panels where bespoke when it comes to the fittings and built on spec by B&O.
Removing the panel is not that complicated though...
Hi All,
I am trying to replace the black bezel with a Chrome variant that comes from a broken panel. Possible? I understand a new panel comes with bezel. Would anyone care to share the service manual. Thanks All in advance.
Angus
You can access service manual if you become paying member on this site.
The bezel is fixed to the glass, if that is what you mean, so you swap the whole thing if you want another bezel.
It is a bit tight on a 46". You will need to remove some plastic on the back panel. Maybe more room on a BV11 55".
Hello,
Can somebody tell me were to find the manuel for replacing the lcd panel on my beovision 11-55?
can’t find it on the site!
i am a silver member, so hopefully somebody can help me out!
thanks
Bart
