Beovision 10
Hello,
does anyone know how to change the coloured panels, the one thats on has magnets the other doesnt and its not obvious how to swap magnets
From failing memory, there were two types. And the Beovision 11 used the second type. They can't be swapped, just use stretch knit fabric to re-cover your original grille in the new color. P.S. Make sure the grille is firmly attached before letting go -- I ripped one fabric corner open by having it fall off, onto the floor. [Edit: Maybe try to buy an old one? One such part # is 1605213, B&O calls that 'BeoVision 10-46 Front Cover Silver'"]
