Beo4, BV9 and Beocenter 2
Hi Need help with BV9, Beocenter 2 and Beo4. Been trying to change all the possible OPT possibilities but just can't get it right:) Beocenter is connected with masterlink and scart to tv. What might be the right option to this setup? Step by step for dummies:))
/api/files/9114ffb36f0d4045994f3e6ebd90c3d7 Page 10 MM
Yep, have the same side open, but still don't get it working:D Now I picture and sound on tv, but still can't use beo4 to controll DVD.......... Is it possible that there is some other solution? If I set options like in that pic Beocenter does not accept any comands - no sound in cd and nothing from dvd. Do I have to have ir in socket box ctrl?
Make sure you have a fully wired scart cable, Instructions are send through scart.
Thanks:) Have check still that.
Thanks for the advice. The reason for problems was that scart cable. I have a box full of those and the fifth was a proper one. They seemed to be fully connected but still there are some difference.....or just broken:) And when you live long enough..............:) Syndicat des Constructeurs d'Appareils Radiorécepteurs et Téléviseurs
^ Good old SCART leads!! I keep a large box of them just in case! (also for temporary connection of DVD1 and/or V8000 to amuse my grandson ?)
