It's an early one made for the Italian market
Type: 35/04 MTI SW1.2
Using an ESR meter I tested all electrolytic capacitors on the power supply and deflection board and I found five bad ones. They where all the same brand and rating 470uf 16V.
I thought that replacing the bad caps would of sorted the problem, but no difference.
Here is a video of the fault: https://youtu.be/hWppZPKIPA8
If anyone knows what the problem might be any help would be appreciated.
Cheers,
Martin.
