The post is based on this thread /forum/the-workbench/beocenter-touch-panel-sensitivity#post-1756855 from the old forum and updated with information on the newer Apple TV Siri remotes as I recently discovered that they had the same capabilities.
Note: I have not found any documentation from Apple regarding control of B&O TV’s. All things listed here is from my own and other forum members observations of the behavior when using Apple TV and Siri remotes with a Beovision or Beoplay TV. I would like to thank forum member Elephant for his original findings that has lead me to experiment further in to these functions. Also big thank to forum member Guy who has supplied with a lot of usefull info both on the old thread and in this new thread.
I have an Apple TV 4 with 1. gen remote connected to a Beoplay V1 and have only tried the functionality on that myself. I have confirmed that the IR commands transmitted from the 1. Gen Siri remote are the same as from my BEO4 remote with an IR Trans receiver connected to my computer.
There might be more functions that can be used that we have yet to discover. If you know something not mentioned here please respond in the thread and I will try to update with all information.
Background
With the introduction of the Apple TV 4 in 2015 it is possible to use the Siri remote to turn on and off the connected TV and control volume either via HDMI-CEC or with IR from the Siri remote.
When the connected TV doesn’t have HDMI-CEC the controls are done with the IR eye in the Siri remote.
Apparently this IR functionality can also use B&O IR codes for some versions of the Siri remotes
Siri remote versions with B&O IR capbility
It is confirmed in more cases that a Siri remote 1 gen. with firmware versions 0x0245 and 0x0257 has the ability to transmit B&O IR commands.
It is also confirmed by forums user Guy that the Siri remote 1. gen, rev. A (white circle) with firmware versions 0x0116 and 0x0118 does not have the ability to transmit B&O IR commands. The 1. gen, rev. A remote can be regocnised by the white circle around the Menu button.
Note that the 1. gen, rev. A remote Siri remote was shipped with both the Apple TV HD (formerly known as Apple TV 4) and the Apple TV 4K (1 gen) so if you buy a used Apple TV and want to get the 1st gen Siri remote you have to confirm that it is without the white circle.
Further It has been confirmed by forums user Guy that the Siri remote 2. gen (with Lightning connector) with firmware version 0x83 and Siri remote 3. gen (with USB C connector) with firmware version 0x33 will also has the ability to transmit B&O IR commands.
The schematic below shows an overview of versions
Login to view image
Setup on Apple TV.
In the settings menu/app on the Apple TV go to remotes and devices enable the functions:
- Turn on your TV with your remote (if it is a TV with DVI port this option will probably be grayed out)
- Volume control: Auto via IR (TV). Note that this option can be grayed out if the Apple TV don't register the brand of the TV with a handshake. This can for example be due to use of an HDMI audio extractor in between the TV and the Apple TV
Login to view image
Setup on B&O TV
The Apple TV remote can only send the source command TV. In order to use this function properly you have to assign the TV source command to the HDMI port used with the Apple TV. On some Beovision TV's this is not be possible when a TV tuner is in use. If this is the case or if you like to use the TV command for another source it is better not to activate this function to avoid weird behavior. On older TV's with only DVI port to connect the Apple TV to the source is usually fixed to the B&O IR command PC.
Turn on the TV with the Siri remote
A press on any of the hard buttons on the Siri remote should make the remote send the TV IR signal even when an Apple TV is not connected.
Sometimes for unknown reasons the Siri remote 1st. gen is not sending the IR signal. I have tried to receive the signal with the IR receiver connected to my computer in these cases, and is not able to pick up an IR signal.
On other forums where other TV brands are discussed some people have suggested that the home button should be hold down for up to 5 seconds or be pressed three times in a row. I haven't seen a pattern where this applies for my B&O TV.
Turn off the TV with the Siri remote
This requires the Apple TV to be connected and turned on. On the Siri remote press and hold the Home button (on the 3rd. gen SIRI remote also the on/off button can be used). In the submenu presented press sleep. After the Apple TV has gone to sleep keep pointing the remote at the TV's IR receiver for a few more seconds. The IR signal will first be sent after the Apple TV is gone to sleep. If you fail to keep the remote pointed at the TV for long enough the TV will keep running but with a black screen.
On a Beoplay V1 it will signal the loss of signal from the Apple TV with the Green LED beside the IR receiver lightning up for a moment.
To clarify how this behaviour looks, try to press the menu button on the BEO4 remote so there is a B&O menu overlay over the Apple TV interface. Do the above procedure and you will se that the Apple TV interface disapeers and a few minutes later the TV turns off.
Is some cases my experience is that the TV will turn on right after it has started turning off. I Assume this might be because the Siri remote is sending the TV IR command when the remote is pressed to choose sleep.
Control volume on the TV with the Siri remote
Press the + or – button's to turn up or down volume. This also works without the Apple TV connected and turned on.
I have not experienced any problems with the volume control function of the Siri remote.
On the 3rd gen Siri remote there is also a Mute button that will work for muting Beovision
Turn on the TV with airplay from an iPhone og iPad
When an airplay signal (music or video) is sent from and iPhone or an iPad to the Apple TV the Apple TV will relay a turn on command to the Siri remote which will then send a TV IR command to the TV and turn i on.
The TV can be turned of with the use of the remote App on the iPhone or iPad.
For these functionalyites to to work the Siri remote must point at the TV and be connected to the Apple TV.
For the 1st gen Siri remote these functionalites are not stable. If the Apple TV has been to sleep before the Airplay signal is sent the connection to the Siri remote is probably lost. Only way to reconnect the Siri remote is to activate one of the buttons. I have found that the connection can only be kept alive if the Apple TV is setup to newer go to sleep and the Siri remote is connected to a charging cable. (I have kept the connection alive for 10 hours over night in my trials). Even when these precautions are taken this will not always work. I suspect that it might have to do with the missing IR signal mentioned in the section on turning on the TV.
Guy's testing with the 3rd. gen Siri remote however shows that this functionality is much more stable with that version.
As you can see all these functions are not stable and that might be the reason Apple has not mentioned B&O in their documentation for the Apple TV 's.
I hope that this at least can be of use to some forum members and maybe help avoiding mystical behaviors introduced by the Siri remote
