BLC System Logs: Client disconnected. Message: Socket error
Has anyone looked into the BLC system logs which is being filled up with tons of errors due to dismissed http response errors? The BLC's that I have are constantly adding the following error entry to the system logs:
Mar 28 21:55:03 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233] Mar 28 21:55:03 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
If the BLC utilise EMMC RAM I would potentially see that this useless generating of logs would wear out the chip and cause the BLC to be bricked. Hopefully this won't happen, but has anyone looked into this?
Hi, yes also here many of these messages:
Mar 28 20:21:12 (none) BLC[1153]: [info]:Using distributed experience for status
Mar 28 20:21:12 (none) BLC[1153]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 28 20:21:12 (none) BLC[1153]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 28 20:21:22 (none) BLC[1153]: [info]:BeoNetRemote is asking current status
Mar 28 20:21:22 (none) BLC[1153]: [info]:Using distributed experience for status
Mar 28 20:21:22 (none) BLC[1153]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 28 20:21:22 (none) BLC[1153]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 28 20:21:32 (none) BLC[1153]: [info]:BeoNetRemote is asking current status
Mar 28 20:21:32 (none) BLC[1153]: [info]:Using distributed experience for status
Mar 28 20:21:32 (none) BLC[1153]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 28 20:21:32 (none) BLC[1153]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 28 20:21:43 (none) BLC[1153]: [info]:BeoNetRemote is asking current status
Mar 28 20:21:43 (none) BLC[1153]: [info]:Using distributed experience for status
Mar 28 20:21:43 (none) BLC[1153]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 28 20:21:43 (none) BLC[1153]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 28 20:21:53 (none) BLC[1153]: [info]:BeoNetRemote is asking current status
Maybe a 100 lines everyday? Not sure if this a lot for the processor to handle.
Regards, Johan
I've open a ticket with B&O Support and they did request additional information and the case is still open after 2 days. So, let's see how it goes. My concern is if the EMMC RAM is wearing out and bricking the device in the long run which I've asked B&O about and what can be done from proactiveness perspective to avoid future issues.
I can confirm those messages as well:
Mar 30 19:44:06 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:44:06 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:44:29 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:44:29 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:44:52 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:44:52 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:45:15 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:45:15 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:45:38 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:45:38 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:46:01 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:46:01 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:46:24 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:46:24 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:46:47 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:46:47 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:47:10 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:47:10 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:47:33 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:47:33 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:47:56 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:47:56 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:48:19 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:48:19 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:48:42 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:48:42 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:49:05 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:49:05 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:49:28 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:49:28 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:49:51 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:49:51 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:50:14 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:50:14 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:50:37 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:50:37 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:51:00 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:51:00 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:51:23 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Mar 30 19:51:23 (none) BLC[1145]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Mar 30 19:51:46 (none) BLC[1145]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
It is a BLC with new electronic inside.
Kind regards,
Rolf
Here's a bunch of errors all within a few minutes.  This repeats dozens of times a day.
From a user perspective, the system appears to be working alright, but if memory wear is an issue, my BLC is not long for this world!
Apr 10 00:18:12 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:18:12 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:18:27 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:18:27 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:30:00 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:30:00 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:30:31 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:30:31 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:30:41 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:30:41 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:30:52 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:30:52 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:02 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:02 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:12 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:12 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:22 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:22 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:33 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:33 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:43 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:43 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:31:53 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:31:53 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]Apr 10 00:32:03 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:03 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:32:14 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:14 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:32:24 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:24 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:32:34 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:34 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:32:44 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:44 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:32:55 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:32:55 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:05 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:33:05 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:15 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:33:15 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:25 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:33:25 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:36 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:33:36 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:46 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:33:56 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:33:56 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:06 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:06 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:17 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:17 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:27 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:27 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:37 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:37 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:47 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:47 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:34:58 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:34:58 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:35:08 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:35:08 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:35:23 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:35:23 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Apr 10 00:35:38 (none) BLC[6286]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Apr 10 00:35:38 (none) BLC[6286]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Looking today at the logs on my BLC, it continues to write thousands of entries a day.
Hopefully the memory won't fail due to abuse, like bnousr suggested above.
