Region Code for integrated DVD in Beovision7-40.
How can I make the inbuilt DVD in the Beovision 7-40 region free.? Step 10 in the Keith Saunders instructions requires LIST on the Beo4 until "Shift" I have 3 different Beo4 remotes , and can't find the "Shift" command on any of them Help needed please Noel.
To add SHIFT to the Beo4: - Press Power (Red Button) and LIST together, the display should read ADD? - Press GO. - Press LIST until the display shows SHIFT then GO. - SHIFT should then be listed under LIST
Hi Guy, Thanks heaps for your reply- I now have SHIFT on the Beo4 ! I followed Keith's instructions , but still not region free. It does say it's important to disconnect the DVB-T module before making the DVD Region Free. Where will I find the DVB - T ? regards Noel.
I assume from the earlier thread that you have access to the 'special' Beo4 remote hence are able to get the REG2 command to show. I too am not sure what is meant by 'disconnect the DVB-T module', but if you look at this FAQ it describes the DVB-T in some detail which may enable you to work out how to disconnect.
Hello again Guy, You're right - thanks to Mr 10% I now have the special remote that shows the REG 2 command. And thanks to your advice , I have now got SHIFT as a command on the Beo4. After all that I still can't make the DVD region free, Regards Noel.
Keith advised me that I need the special remote that has "Special Command 2" on it, Regards Noel.
