Problem with Beosound Core and local sources
Firstly, I would like to echo what YannChris said about the lack of user manuals, I have spent ages going through every screen I could find to try and set up the Core.  I have only just found the screen to tell the Core what type of speaker it is attached to! I have a Beovision Eclipse,  Beomaster7000 (with CD, Cassette tape, Beogram and a OneRemote), and a NL/ML converter. On the setting up local sources screen, I can see all my Eclipse and Masterlink sources and have selected the ones I want. But on the screen to select the source to play I can only see one Eclipse source and one Masterlink source and I think these were there before I selected any local sources. Any ideas on what I can do? Also, I thought I would have B&O Radio on the Core but have Tunein. Regards Paul
I don't have a Core, but on my Essence, when I check the local sources, they immediately show up in my sources pick list The fact that you're not seeing B&O Radio, maybe you need to upgrade your app?  Also, go into the TuneIn/B&O Radio tab on the app (the little transmit icon in the lower right corner of the app), and click on the B&O Radio tab, this might prompt for a TuneIn -> B&O Radio upgrade.
The app shows B&O radio but it also says the Core does not support it. Will carry on investigating.  Paul
Look for an upgrade to the Core software.  The latest should give you B&O Radio.
An update. I did a factory reset and this time I made the BLC the primary Beolink product and the Eclipse the secondary Beolink product and I can both select the Masterlink sources in the local sources screen and then choose them in the app and on the remote. I can select the Eclipse sources in the local sources but they do not show in the app or the remote.  I can join a playing Eclipse source. Still no B&O Radio and I appear to be at the last version of the software, 2.1.50871.22855122. Paul
I have 2.1.51942 for my Core/Shape.  To be fair, I was a member of the beta test team for a time; nevertheless,  I believe this is the current release version.
Carola, thanks for that about the primary,  I thought I had seen something like that but couldn't find it. I have spoken to my local dealer who sold me the core and they said the same about the preference but I already had it set. They have raised a call with B&O about B&O Radio. Will report back on response.
Just had a response from B&O support. It is a known issue which they are working to fix. There is a temporary solution to switch the radio back to Tunein and then back to  B&O Radio, this works for me. It might be that I migrated to B&O Radio before adding the Core.
I'm also waiting patiently for this issue of the secondary linked products not being accessible in the local list menu to be fixed. It affects all of my ASE products on the new firmware with b&o Radio.
