Ouverture glass door hinges glue?
This has been up before and I have found threads i the old forums about it, but just to be sure:
Are there any known method to reattach (glue?) the hinges on the glass doors from an Ouverture. I guess one of the difficulties is to reestablish the black coating.
picture below of one of the defective ones I have
Login to view image
Inn my attempts i did break the black coating, but from my experiments I found Loctite Extream repair seems to hold. I can remove the doors without it breaking, but how long it will last I do not know.
I tried epoxy, but that didn't last very long in my attempts.
Thanks for the answer about the glue type :-)
Was the black coating broken because of the glue or was i from the removal of the brackets?
The black coating was ripped off when the Epoxy failed. I not noticed the Extram Repair affecting it. Tho I supose its possible my glue got better adhesion without the coatin ginn the way.
My thinking was it was worth trying. worst case i break a panel that is allready scratched up and according to my Local B&O store they had spare panels in stock.
Thanks for clarifying. I might try this on some of the panel with broken of brackets I have
Hi Mads,
I (vaguely) a topic on BW1: a guy who used to do lot of cosmetics repair (Leslie…) did polish the glass – maybe with some sort of acid) where the black square is then painted it then use epoxy glue. The result was nice.
About epoxy glue not holding well: I glued the glass of a BS9000 with 2 components epoxy and it is still holding strong 3 years in vertical position and 3 years in horizontal hinges down. Moreover one hinge is lacking the spring which must put some more strain on the glue. Also glued many BS2500 glasses without issue. I would do the same if I needed again.
Cheers.
Edit: One more tip from the past:
I have tryed al lot of glue. But this one does every time the trick for me.
