I have an Ouverture, it has been working fine , but after the recent Ciaran storm and the clear up afterwards, which continues here in mid Finistere, I experienced a short power outage over the weekend, the Ouverture was working when it happened.
The power came back on, and subsequently I booted up the Ouverture, it started playing a strange station on FM, when i tried to retune it it wouldn't, so looked at the display and, strangely the indicated frequency range on fm is now 70.2 -> 90.0 mhz, can anyone tell me why this has happened and also how do I correct it, or is the unit knackered.
Is there an easy why back to factory default or do i just delete everything and switch the unit off for a couple of days and then try again??
