Ouverture and 1656
Am new to this forum, forgive me if I ask a double question.
I got a BeoSound Overture from my mother, bought 2 passive speakers from Kenwood, but am still looking for an amplifier. I read an offer for a 1656. Is that a good choice? The intention is to listen to the system in 1 room only.
Thanks in advance for the reply
Hello and welcome to the forum
The 1656 Beolink Passive should work just fine for your purpose. One important note is that you need a fully wired powerlink cable between the ouverture and the 1656 for it to work.
you might also be able to find the box named as ML-MCL converter with a different type number. It is the same box, it can just be used for other types of setups also. If an Ir eye is bundled with a ML-MCL converter you wont need that in your setup.
hope this is helpfull
