what I have done is that I run a toslink cable from my Mac mini into the Beosound core.
I could also run a toslink from my Apple TV into the Beosound core.
is there any other way to get a lossless Apple Music signal into the Beosound core?
With that I certainly agree. But Leo asked: “is there any other way to get a lossless Apple Music signal into the Beosound core?” And that was the question, I tried to answer. I guess a lot of people prefer a wireless version (AirPlay) and also not many use a Mac as the daily music driver. For me the bigger question though, is whether the difference matters - and if not the convenience of wireless is worth it? That is a question, that only the actual listener can answer. Maybe the mastering quality, the listening room and the speakers (and ones hearing ability) are the more important factors! MMAgain technically speaking if he want to feed the Core with a higher resolution music files from his Apple ecosystem, then he has, to my knowledge, skip AirPlay altogether and use the toslink connection.
We both did - skip Airplay: do it, as you propose, with an external DAC connected to an iDevice or use the the Mac.But Leo asked: “is there any other way to get a lossless Apple Music signal into the Beosound core?” And that was the question, I tried to answer.Again technically speaking if he want to feed the Core with a higher resolution music files from his Apple ecosystem, then he has, to my knowledge, skip AirPlay altogether and use the toslink connection.
I guess a lot of people prefer a wireless version (AirPlay) and also not many use a Mac as the daily music driver.I prefer LAN connections; so everything, when possible, is LAN-connected. That said of course I use (DLNA) controllers much. For example I use Audirvana to stream Qobuz directly to B&o devices.
For me the bigger question though, is whether the difference matters – and if not the convenience of wireless is worth it? That is a question, that only the actual listener can answer.
Maybe the mastering quality, the listening room and the speakers (and ones hearing ability) are the more important factors! MMYou do, as I do, listen to "the Harmony Codex". "Abbey Road" and DSOTM in Dolby Atmos (correct me if I'm wrong). But in the end, I completely agree, its up to the listener. "Hires" is a hopeless discussion, because everybody's senses, tastes and preferences are somebody's own; atop of the physiological and technical discussion. I did set my preferences on my experiences. regards
