I'm not sure if I'm asking the right question, but it seems to me that there are different B&O IR-eyes (active room version with wall-mounted control for volume and timer, TV versions (IR-eye only), and I don't know which other versions are out there).
I'm trying to connect one such IR-eye to a Beosound Exxence MKII and want to be able to control it with Beoremote one. I don't mind if it has volume and timer functions, but it needs an RJ45-type connection to connect to the BS-Essence.
Do you know which IR-eye (model/part number) I should get?
