Intermittent buzzing on Overture
Dear all. Thanks so much for the advice on the screws earlier. The reconditioned overture occasionally makes a sort of raspy buzz. It's quiet, when the CD is playing, and isn't a big deal when the volume is up. Any thoughts?
Hello Matt,
Not so easy to judge from your description I think. You write that it has been reconditioned, would it not be an idea to record the noise (maybe even film the Ouverture when it happens) and ask the seller/reconditioner? I would say that if it was sold as reconditioned to you, it should be working flawlessly, and the seller should feel responsible for it.
Regards, Johan
Regards, Johan
Some electrical appliance nearby? A refrigerator, perhaps at the opposite site of the wall?
Bad Powerlink wires? Are they original? Long? Short?
A telephone can make this noise when it checks the net connections.
"Bsssss bada bada bada...."
Even a brandnew Overture will show this sound, it was never designed to withstand this emv noise.
Also a computer or router can cause these problem, also some bad LED lights from fareast...
