How do I fit a Beosound 9000 table stand?
I have just bought a table stand for my Beosound 9000. It came with 4 bolts with spacers. I know I have to adjust the tensioner on the back to change from flat to upright. I do not have the red key. Can this be done by carefully using a screw driver? Or would it be better to find some suitable plastic and cut a key? I also know I can change the display by turning the manual control panel and spin the logo on the clamper. I can see some simple diagrams on the Web of how the BS9000 goes on the stand but no detailed fitting instructions saying where I put the bolts and how they fit to the stand. Any assistance would appreciated, especially photos or the PDF manual. I want to stand it in the "upright" position. Many thanks, Stoobie
Exeter, Devon, UK
Hi Stoobie, You can use the user manual for the
Thanks Matador, That is just what I need. Any thoughts on the adjustment with a screwdriver? Stoobie
Exeter, Devon, UK
Oh yes sorry, No problem at all. Screw driver or any flat head shape. They are not screws, more locks or something mounted on a spring. you just push them gently and turn them until they click in place. Not risk to break anything in there.
