How disconnect multiroom on Beosound Essence and remote
Hello, How to disconnect multiroom on Beosound Essence and remote essence ?  Cause I have no multiroom only  Beosound Stage and a Beosound Essence. Thanks
Hi gumbots Actually you have ‘a Beolink multiroom’. Your two devices - Stage and Essence - do build a B&O network assuming they are on the same home network. But why do you want to disconnect? MM
Thanks Millemissen,
'Cause I don't need à Beolink multiroom they are in the same room. Yes Essence and Stage are on the samedi Net work.
Then just use them independently - nothing forces you to use multiroom. P.S. I suppose that you have speakers connected to the Essence. What does the Essence Remote control? MM
Good morning Millemissen, Yes I have speakers connected to Essence. I see the Essence Remote control only The Beosound Essence.
What is it that bothers you, what do you miss??? I guess I fail to see your problem. Maybe someone else can chime in here. MM
Hi Gumboots, I have the same question. Since Millemissen is curious as to why, not that it matters, at my end, I'm trying to undo Multiroom and then re-set it up as I'm not seeing the same image I saw earlier with the first set up in my B&O app. Maybe someone out there knows. If not, I'll just ask B&O support. They're pretty good at replying quickly and professionally. If I find out, I'll post again.
