Does the Ouverture have a supply fuse fitted?
I have a dead Ouverture, as above is there a mains fuse fitted, if so where?
I am about to start wading through the service manual to look see!
You replied just as I was splitting your BV6-26 question to a new topic, so I have moved your response to there and will reply.
Let's keep this thread related to your Ouverture question, which you were going to investigate further as you had found the circuit diagrams..
Yes, found the fuses, 5 of them, checked with continuity facilty on multimeter all ok, however 2 x connectors from the power board to the adjacent were a little loose, just about to reconstruct the beast to give it another go, hopefully it will be fine  --  that should just about see the afternoon out!
No  progress this afternoon, my neighbour visited for a chat, hopefully tomorrow!!
