Can I use a regular 12v DC power adapter for Encore 5?
Hi, Can I use a regular 12v DC power adapter for Encore 5? I lost my original B&O power adapter.  I'm thinking to modify the DC power cable. 1. What voltage is required? 12v? 5v?    Do I require 2 separate voltages to power up? 2. What's   IR   at pin 4?   I don't require to link to external speakers or such, I'm only using the headphones OUT jack. So just looking to power up the Encore 5 will do. thanks in Advanced!
i realised my connector is this... does anyone knows which pin goes to which?
I would suspect that 2 of the pins is Ground and probably internally connected. If you have a multimeter you could do some continuity testing to find out if any of them is connected. hope this could help you a little
