Beosound Stage is turning my LG A1 Oled on every night around 2.30am.......
As the title says really, my Stage is turning on every night around 2.30 am, not exactly 2.30am but around that time. I have checked all timers, I have tried every setting and turned off auto updates as thought it could be related to it searching for an update around this time. I have updated all software, on the TV, the stage and the app.   I had some Sony Linkbud S headphones hooked up to the TV for listening late at night, as this is in our bedroom, so even more annoying when the thing turns on, and deleted them from the TV and thought it had sorted it, but after a couple of nights of peace it started doing it again. If I unplug the hdmi it doesn't happen. That can be repeated.   I have reset the stage but doesn't help.   I saw on a couple of other posts saying the same but no conclusion. Any ideas? Thanks.
I have the same issues, but it's not every night, it just happens every now and then. I have not been able to find any pattern, but truly annoying to come down in the morning to find the TV on...
Even more annoying when it is in the bedroom and it lights the room up and wakes you up! Haha Sometimes you can turn it off and it happens again an hour later too.
what happens does it happen, if you unplug (only) the Stage from the mains?
If the stage is disconnected, either hdmi or mains, it doesn't happen. 2.30am and again at 3.30am. It has to be a timer. I have just checked the log to my Fritz! router to see if that is doing anything, but doesn't seem to be. I also have BT homehub discs only. Fibre provider is zen.   Just mentioning in case network is waking it and someone has the same hardware.
I am having a similar problem with my stage. I will turn the TV off, stage will turn off then 5 min later the stage will turn everything back on. It doesn't do it every time, it does it randomly but always around 5 min or so after turning everything off. Very bizarre.
No devices connected. Updates turned off. I have spoke with B&O and they are asking questions. But looking round there are posts on avforums, AVS and elsewhere, so not individual issues. It did it with my Sony XF9005 before as well, only a few times, but it did do it.
It's going to be interesting to hear what they say in the end. Please keep us posted.
I’ve had the random turning on event with my LG connected to a Stage. It has only happened 3-4 times in the 18 months we’ve had them, and doesn’t follow any pattern.
