Beosound stage in combination with Beosound 1
Hi everyone,
I currently have Beosound 1 as main speaker for listening to music and I am wondering to add Beosound Stage in the same room for better music experience. Does anybody know if I can combine Beosound 1 and Beosound Stage in the same room as connected speakers? I have some concerns about the sync between both speakers and possible delay/lag between them.
Thanks a lot!
You are able to use them simultaneous, using Beolink. Meaning you start the source on e,g Beosound 1 and then add Stage to that play (ideally using the B&O app). They will play in sync.
Both need to be on the same network.
(I assume your Beosound 1 is the conic aluminium speaker :)
Noticed just now that you wrote "connected". Its not possible with physical connection. BS1 has no Line in / Out.
