Laser eye to be cleaned/replaced. Common fault.Will try to clean it before I take anything apart to check if that helps.
ape belt, common fault again. Full tutorial on the old forum, unfortunately with pictures missing. 2 hours work and quite an adventure but pretty sure that’s the fault (three Ouvertures, three time the problem).Thanks for the heads up about estimated time consumption :-) I found the thread here /forum/imported-unmapped/accessing-beosystem-2500ouverture-tape-mechanism-for-belt-replacement A google search for Beoworld Ouverture belt shows a thumbnail of one of the pictures in the search result.
