Beosound Level
So I was eying the Beosound Level for a while but held back since it would not integrate with my Essence pending Software upgrade. I lost a bit track but the US site is still talking about pairing with chromecast and airplay.  Did that rumored update nor materialize? Other question I have, I would want the google less version, Is pairing 2 in Stereo working nowadays, specifically with Spotify Connect? Best JK
Hi JK, I’ve tried to link in YouTube links that the forum didn’t allow to post here. The Level now supports: - Spotify Connect - stereo-pairing using the native B&O app (note that you need two of the same version, so either two Levels with Google Assistant or two without) - Beolink Multiroom using the native B&O app, so you can now connect to your other B&O devices that are pre-Mozart and Beolink-enabled. My two non-GA Balances that I have work flawlessly both in multiroom and stereo  (as you probably know the Balance like the Level uses the Mozart platform).
Hi JK, I myself have two Balances which use the same Mozart platform as the Level and while I don’t use Spotify a few months ago B&O released a big Spotify Connect update so I think it should be supported on the Level now. I’d say it should work in stereo even if the B&O website doesn’t mention it specifically here other than that the Level supports Spotify Connect: https://support.bang-olufsen.com/hc/en-us/articles/4418029319825-Does-Beosound-Level-support-Spotify-Connect- John from B&O Manchester gave an update on the latest way to stereo-pair Mozart products here so that I know from my Balance works with the Level: https://youtu.be/JkburfkgC7o B&O Manchester also sums up the other recent big software update that enables Beolink multiroom as well: https://youtu.be/K97lFWzq4yw So I think it is very likely that you can now do all those things. Anybody that can confirm?
