Beosound Core - Optical-In to TV not working
Hi B&O Dreamers, I have a setup (see below) including a Beosound Core as end piece to a TV via an Optical cable, but no sound comes out of the BL18 speakers. Any ideas how to make it work? I tried to change the source on the B&O Mobile App to Optical-In and still no sound.
[BL 18] via WiSA << Transmitter 1 >> [BL 18] via WiSA
PowerLink RJ45
^ Beosound Core Optical-In TV
Did you set the sound of the tv to PCM/stereo - and to output from Toslink - in the settings there. Please be aware! Depending on the tv brand this might be named differently in the settings. MM
In my case, I connected the SONY TV to the Transmitter 1 and the TV automatically switches to Optical output and plays sound. Using Transmitter 1 is not option because I could not lower the minimum volume which is too high. The Optical out min volume could not be lower by the TV too. But if I switch to the Beosound Core, no sound comes out.
The Beosound Core actually has only Optical-Out port. Topic to be closed...
Isn't it optical INPUT?
Sure - that is the combined analog/digital input port, that is available on many ASE-based devices. Just to prove that Paul Jordan was wrong ? about the BS Core. MM
