Beosound A1 Gen 2 Aux input
Has anyone figured out how to send analog audio to the Beosound A1 Gen 2.  I want to connect it to a turntable (with built-in RIAA amp) for my daughterm but can't seem to find any information on whether this is possible. In the old forum, there was a post talking about why it was difficult, and why various solutions like ADCs and Belkin devices do not work. Any solutions?  Does Steve at Sound's Heavenly have any magic cables? Thanks, Stan
Hi Stan, I have been checking the A1 FAQ's and Manuals but you are correct, there is no information about the possibility to use the USB C port as an analogue line in connection. From what I have read and
Thanks for the answer.  Not the one I was looking for but confirmed I'm not overlooking anything.  I was hoping to avoid Bluetooth because it can be flakey, but it looks like the way forward... at least until she decides to upgrade to something better.
Hi Stan, You need the A1 mk.1 if you want to use an analogue wired input, as there is no way to do this with the mk.2 version unfortunately. Kind regards, Steve.
I have a gen1, but it is currently being used.  I have a gen2 that is available.   I don't really want to buy a 2nd hand gen1 because of age/battery life.  However, it is good to know that analog input to the gen2 is not an option.
