Beosound 9000 with 3x BeoLink Passive zone issues?
main unit Beosound 9000 main zone 1x Beolink passive via powerlink 2 rooms 2x BeoLink Passive with BeoLink IR receiver via Masterlink   main room works fine. issue I have is If both Beolink passive are plugged in with masterlink then one of them is not responding to beolink ir receiver (eye) if i unplug one of them other one does works fine. that got me into thinking reprogramming eye with beo4 remote with no luck atm as i said if all is plugged in then one is working 100% and other remote lights coming on but not responding - play button stays RED after pressing it. any ideas?
Hi and welcome to Beoworld! Have you tried swapping the IR sensors between the two passives, to see if the fault follows? I would suspect cabling of one of the IR eye's to be either incorrect or disconnected, either inside the sensor itself, or inside the DIN connector.
Hey Guy yes tried that if I plug IR sensors alone they work in both amps but if they both connected then one doesn't work. one guy that does work with B&O suggested program eye via boe4 tried that with no luck so far. its like its not switching to input or source. https://share.icloud.com/photos/0beSPkFx2lgbK2WGc-l0QIf3w
Maybe try checking the ML connections:
  • Power down the complete system (unplug from mains, including main room BS9000 and Passive).
  • Unplug all the ML connections.
  • Make sure all the ML plugs are clean and undamaged and that there is no dust or fluff inside the sockets.
  • Reconnect the ML cables
  • Power the system up again.
  • Re-do the option settings (put the main room in A.OPT 1, and each link room in L.OPT 6).  If you need instructions for this, let me know.
Then try control again.
A further thought:  In the main room is the ML cable connected directly to the BS9000? (I only ask this because you have a Passive in the Main Room, but I assume that this is just acting as an amplifier and should only be connected to the BS9000 by a Powerlink cable)
correct passive in main room connected from bs9000 by powerlink acts as amp... ML is direct from bs9000 to both or passives in other room. when only one is plugged in that room works when i plug 2nd one only one works. if i only plug 2nd one 2nd one works with no issue. I think its going to be something to do with L.OPT... I'll try tmr nights
Hi in my personal use I try to use the Beolink passive with the powerlink but its no work, do you know if I need to program the Beolink passive with Beo 4?
Caviste passionné de B&o avec une légère collection: Beolit 15, Beolit 20, BV7-32 MK6, BV Eclipse 55, Beolab 17, Beolab 6000, Beolab 2, Beolab 14 2-1, Beolab 4500, Beogram 4002, Beogram 1900, Beogram 6500, Beocenter 2, Beosound 9000, Beosound Ouverture, Beolink NL/ML, Beosound Essence MK2, Beolab Transmetter, Beosystem 3, Beosystem 4, Beoplay H6, Earset... Etc.
Hi, I have a similar issue. I have a 9000 connected to a passive and ir eye. The IR eye and passive were working fine.. then... I used my BEO5 to turn on my Samsung tv. After this my eye no longer responds to the remote or touch (ie using the buttons on the eye). I have unplugged everything a million times and replaced the cable for the eye. Any ideas? Thanks
