Beosound 9000 Test Modes and F1 Fuse
Hey team, I’m working on a 9000 that has the following issue: sledge will not move, shuts down and reboots after trying to change disk. After a few tries it will blow the F1 fuse. To my dismay, this has happened 3 times. If device sits on RADIO mode it works fine, but if I switch to CD it will freeze and shut down every time. Trying to get some input before I blow some more fuses, any input here would be great. I also have an issue getting into the test modes with BEO4. Every time I press SHIFT + 9, it goes out of the shift mode to CD. I cannot input the full 90258 code in SHIFT mode.
I'll have to experiment more. It seems like any time I press 9 while in shift mode, it immediately leaves shift mode. Does SHIFT have to display on the screen throughout the full 90258 code? And of course since SHIFT+9 is a CD code, it brings it out of standby every time.
You could also try pressing GO when SHIFT is displayed on the screen, and then press 9 0 2 5 8.  This works for me also with BS1.
To get into Test Mode with a Beo4 first make certain that "Shift" displays when you scroll through the available commands (press List until you go all the way through).  If it doesn't show up, you need to add it.  Once it is available on your list, select CD on the remote.  Then, as Guy instructed, scroll through the Beo4 commands until Shift is displayed.  Then enter 90258, this will enter Test Mode and CD will be selected.
