New here as a member but have been here as a guest many times surfing for repair methods, thanks for all the info so far gleaned. A new problem has arisen and I am hoping to find a probable solution before I start the strip down.
Started the other day, changing disc from 1 to 3 and the shuttle dropped to the bottom, 9000 is installed on a vertical wall mount. The 9000 turned itself off and would not do anything..Today I have removed it from the wall so it is now flat on a table, plugged in and switched on and the shuttle drove itself back to position 1 and everything was working as it should, lifted it back up to vertical and this time it changed from 1 to 3 but would not return, got confused and again shut down, lay it down and power up again and it works again.
I am hoping this is just something slipping, I am competent to open it up and carry out a repair I just like to have a bit of insight first, if there are any known issues or likely causes I would be most grateful, Thanks in advance..
