Beosound 9000 glass door appears to sit too low/push down
Just bought one of these. The glass sits too low and touches the CD mechanism making the assembly jitter between CDs and make clickingnoises when playing. Everything works smooth and quiet when i slightly lift the glass door manually. What could have caused this -and do anyone have ideas for a fix? Apparently it has barely ever been used, and sat in a closet/cabinet most its life
Did you solve the problem? I have a unit with the same problem …
thank you
Hello. I have the same problem, did you find the solution? Thanks a lot in advance 👍
Check service manual (available here for silver and gold members) for glass door height/angle adjusment.
Two Screws, easy work.
Hello! Thanks a lot, it solved the issue 👍🏻
