Beosound 5 option question
What option setting is recommended for a BS5, that is not connected to MasterLink and has no speakers connected to it? Only use is the line out connection to a ML/NL converter? Thanks!
Hello Razlaw, I would say option 1? The only 'no speakers connected' setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view. "The music system has five different Option settings: Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system. Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system. Option 2. Used when your music system is set up in one room and connected to a video system set up in another room. Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television. Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television." Regards, Johan PS - why not ML connect it to a BLC and enjoy control from other devices?
Thanks!  Your thoughts are just what I had come up with experimenting and looking at the manual. I am not connecting it by ML for two reasons. First, I have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected.  Have spent many hours trying to get both  to work together well.  The BS3000 would need a new chip with Option 5.  Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio.  The BS 5 has pretty much been a wall decoration for years. If connected with Line In I can at least feel like it is functioning part of the system and listen to the music stored on it occasionally if I want to.
Seems a cool idea - definitely worth trying out. I guess that the line out is at fixed volume, since it was used for a connection to a tv (integrated setup), where the volume is controlled. The line-in of the converter has auto sense, if I remember correctly. Looking forward to hear about your findings. MM
Connecting the BeoSound 5 to the Line In on the converter works fine, with one exception.  I can not join Mozart products, only older NL products. What makes it weird is I can join my BS3000 through the converter to Mozart products. I have Beconnect Core ordered. I am sure if I connect the BS5 to the line in on it, it will all work. I will probably try it although the intended use for the BCC is to use with my BL1s.
What sort of control do you have the BS 5 with that option?
Hi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
Thanks!  I will consider another converter.  Today I connected the BS5 to line in on a Core. That does allow it to be distributed to all products, Mozart included.  Of course can only control it in the room where it is located.
