Reason I ask - I bought an ML Gateway a little while ago as part of a few things bought as a kit. I was going to sell it as I thought I had no use for it, but then learned (from a helpful reply to link thread) that it might be of use to me after all - I could set up virtual buttons that I can use from a browser, and set up macros I can trigger with my Beo4 - sounds nice!
Problem is however - the software on my Beosound 4 is the earlier version that cannot talk to the ML Gateway. I'd need to somehow update the software to use it.
I also tried on my Beovision 8 by the way, but the instructions for enabling an ML Gateway connection on that are also not working - instructions found on the say to enter the Customer Service menu you should go into the menu, and then while Connections is highlighted, hit Red+Go to enter that menu. I've tried that but nothing happens when I press Red+Go. My BV8 software is up to date.
