Beosound 3000 software EEPROM
Hi there - does anyone happen to know where I might be able to buy a software EEPROM for a Beosound 3000? Mine has software v 1.0 and I'd like version 3.2 (which I think is the most recent). Obviously a discontinued part but just wondering if anyone knows of a supplier of old parts? I'm based in the UK. Many thanks Luke
Many thanks Beomedia - I had visited that site, but unfortunately postage costs to the UK are really high (almost 5x the cost of the item - thanks BREXIT!). I was hoping there might be another option
Hi again Luke, I emailed OneRemote a few days ago about a similar sized item and they said that they could do 'letter sized' UK postage for about €21. They even added a checkout box for me, but in the end I didn't buy the item anyway. It's probably worth getting in touch with them by email. (They did also say that they can send stuff anywhere in mainland China far cheaper than to UK!) EDIT: You could also try
Thanks Guy- good shout - I’ll give that a try ?
Is that eeprom the one that use to "fry" and brick the whole unit?
Just to say I cannot speak highly enough of the service from OneRemote - thanks all for your input. with best wishes Luke
