Beosound 2500 Hint needed
Dear,
I^m looking for some hint to get further.
I`ve got a 1993 Beosound 2500 on my table to fix the standard items. All 3 belts new and a new Battery for the static RAM. So far so good. Full system worked properly directly after fixing.
I thought jobs done but, then after a longer test run I recognized the doors kept close. Even though that worked before pretty well. After reset (plug out for 5 minutes) the systems worked again without any fail. After another 12 hours standby mode the doors blocked again. After new reset it worked for another 24h till the door kept close again.
Additionally the CD couldn`t be started by remote control but, radio and tape does.
My first idea is maybe a Capacitor is the reason since the time it takes. Maybe one around the RAM Circuit - there are only 2 of them. But this is juggling. Maybe some of you out there have an idea or a simmilare picture in the past. Let me know and share your thoughts.
Thanks in beforhand
Joerg
(from very Norther Germany)
