Tried all troubleshooting as recommended (checked the volume and sound levels, factory reset by App, reset by hardware button, delete and reinstall the App, change the Android device, create support ticket in B&O support and sent logs, small video etc). B&O is saying that very likely it is a hardware failure, so I have to go to retailer who will send product for repair in Denmark , will take one month etc.
App works normally, playing music from my regular sources Radio etc is OK, however I hear only bass sounds, no treble. Checked on B&O M3 player in multi-room configuration, M3 works normal.
Just wondering, as I did not found any similar user issue on web / B&O support sites/ forums, how this can happen, tweeters are dead in less than 5 years?
There is nothing particular about the operating environment, standard living room, standalone usage etc
Thanks in advance
