Beosound / Beolab with record player / phono line in
Hello there! I am very fortunate to own the Beosound 2 (gen 1) and Audio Techica lpw-50pb record player. Currently I am using internal phono preamp included in record player itself (AT LPW50PB), and just the RCA to line in cable connected to Beosound 2. I do not notice any lag nor dissortion, the only drawback I can see is the sound is noticably lower than from other sources (spotify). Firstly what do you think of such setup? Should I upgrade of extaernal phono preamp or is there other way to improve the listening experience? Secondly I am looking to upgrade to Beolab 28s or Theatre, and have the similar question: what would be the best way to connect Beolab or Thatre to the record player to have the best experience possible?
Did you try adjusting the line-in sense options? Please have a look
I didn’t get much difference when I switched between line-in sensitivity so I stuck with ‘medium’. For pure audio, you’d be better going the 28s route. I went with the Theatre and have a couple of BL3s as rears. It took me a long time to get a sound I liked from my Beogram record player with this setup and it is still a work in progress really. I have the Beogram (no internal phono preamp) connected to an external phono preamp, then a 1 meter decent RCA to mini Jack cable to a Beoplay M3 with volume set to 0. (The m3 Millemissen’s great idea!)  The M3 is wired to the home network and I use Beolink multiroom to play the record player through Theatre and sometimes just BL3s as I can assign speaker groups. I use BR One for volume, and Join function for multiroom. alternatively I could use 12m of line-in cable to the Theatre but when I tried that, did not sound good.
