Beosaund Emerge
Good afternoon! I want to ask if it is possible to use the beoremone one remote control with Beosaund Emerge to turn on/off, control the sound and switch radio stations, the list of which I have selected and saved in the B&O App. I would like to make all the settings in the application, select and create a list of Internet radio stations, and use the beoremote one remote control for everyday use. Is this option possible, or is BS Emerge managed exclusively using the B&O App via a phone or tablet?
According to the B&O website, BR1 can be paired with Emerge.
Check this:
/api/files/7d213437c0ca42f8ab1b3757db359b93
Kind regards,
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
I use a BR1 paired with a pair of Emerges.
Very cool! Tell me in more detail how do you use BR one? How do you synchronize the selected list of radio stations in the application with the remote, do you switch radio stations from the remote? The selected radio stations, for example B&O radio in the application, are synchronized, reflected on the remote display and when you press the "music" button, you can see the list of radio stations from the application on the remote display and change them using the arrows of the BR one remote? Or is it happening in some other way?
Actually it is quite simple.
Supposed you have made a list of your favourite B&O Radio stations in the app….
After you have set up the Beoremote with the actual product - using the app - this list will be available in the display of the remote, when you choose radio (from the Music button) and right click (there is an arrow there to indicate that).
After that you can scroll with the up/down arrows through the list to the station, you want to listen to - then press ‘Go’ (the big button in the middle).
Thank you for such a detailed, clear and informative answer. This helped me a lot, since none of the instructions reflect this. I congratulate you and your loved ones on the Bright Resurrection of Christ - Easter.
There you go ?
