I have a B&O Century and I lost the remote so I ordered a BEO4 remote and I just can’t get it to work with my Century - are you able to help at all please ?
B&O Century Remote
Hello,
Hi and welcome to Beoworld!
The Century may be in A.OPT 0, where it will not respond to IR commands.
To resolve this:
Turn to standby/off.
On the Beo4, press the POWER button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show A.OPT. Then press 1. The power light on the Century may blink to show that it has been accepted. (EDIT: The digit '1' should briefly be shown on the Century's display)
Remote control should then work.
If the above procedure does not work, check that the Beo4 is actually transmitting IR signals by viewing the end of the remote with a mobile phone camera (selfie camera if iPhone). You should see the IR transmitters glowing when buttons are pressed.
To resolve this:
Thanks so much Guy, do you mean do this on the remote or the stereo itself as I tried it and it still doesn't work, I checked the IR an that works ok.
Thanks for all your help
Thanks but the remote seems to be working with the camera test, am I correct in saying that the BEO 4 is the right remote for the Century ?
Thanks so much Guy, do you mean do this on the remote or the stereo itself as I tried it and it still doesn’t work, I checked the IR an that works ok. Thanks for all your helpYes you do this on the remote. The Century itself should be at standby while you press the button sequence on the remote.
If my earlier suggestion doesn't work, there is one other possibility: the Beo4 could be set up in permanent 'link' mode, which will not work correctly with the Century.
To check this:
On the Beo4, press Standby (red dot) and List together
Press List till CONFIG appears
Using remote keyboard, enter 2 0 0 2 , the display will read LINK ON (or LINK OFF)
Press Exit
If necessary, repeat the process to get the remote to say 'LINK OFF', which is the option that you require.
To check this:
Press Exit
Thanks - I have got it to say link off as it was on but still doesn't work, is there a way to reset the remote or anything ?
thank you
thank you
