Which remotes have Phono button?
Quick question - which of the later remotes still have Phono available as a source to select?  I have a Beo4 Mk41 and a Mk4.  I can select Phono (via the List button) on my Mk1 but not on my Mk4 - I have to use N.Radio instead. That works, but it's annoying!
So, I was thinking of getting either a Beo4 Mk2, Beo4 Mk3, or Beo5 for that room, but I am not sure which versions have a Phono button available - can anyone tell me?
That's odd, why is it doing that?
Of the Beo4s, I think you are safer to go for the Mk1 'AV' version to get PHONO.  In my notes I have written that PHONO may have only been available in LIST prior to Beo4 SW 4.2, but I am not at all sure if this is correct!
There may be a Beo4 SW version that will show both PHONO and N.RADIO - possibly one of the early Mk2s (SAT, DVD version) that was introduced in the early days of N.RADIO.
Not sure about Beo5/6.  (EDIT:  I just checked by running the Beo 5/6 configuration tool and it does allow you to chose PHONO as a source displayed on the screen - I combined it with BC9500 in this instance.  I haven;t checked with a physical Beo5/6))
But have you considered BL1000 which has PHONO written on the physical button?  Or even Beolink Audio Terminal?
Beoremote One (non BT): Rename N.Radio in Phono
Thanks both.  I already have a Beolink 1000 but that's in use in another room.
In this room, I also have a Beovision 7, and while a Beolink 1000 will control a BV7, a Beo4 is much better for that.  That's why I'm thinking of another Beo4, or I might get my first Beo5.
I'll see if I can get a Beo4 Mk1 or Mk2, or maybe a Beo5, as your test
Beolink 5000.
Update - since posting this question I have discovered that the Beo4 Mk1 and Mk2 both seem to have PHONO available as a List button you can add.  The Mk3 and Mk4 do not.
It may be dependent on the software version, but I currently have one each of Mk1, 2, 3 and 4, and that's what I've found on these.
A little down this page
