Remote - Using Multiple B&O Devices (only) in Same Room
Hi. Is there a way to control different B&O audio (only) products in the same area with a Beo4 without activating them all at the same time? For instance, if I want to use the CD on my Beosound 9000—-my Beosound Century, my Beosysten 2500 and my Beosound 1 all turn on at the same time. Is there anyway to program each B&O (only) audio device (only) without turning on another source in close proximity of each other. Perhaps I should say control different B&O audio devices to operate separately. Note - I don’t care about “non-B&O” products and I don’t care about nonsense like B&O “TVs”, “lighting”, “Bluetooth”, etc. made by other companies for B&O. This subjects is covered extensively on Forums. I have no idea why as B&O means audio! I also don’t get why anyone would ever care to use their “non-intuitive” (sorry, I love B&O) Beo4 remote on a non-Beo device when it is arguably the worst remote control device ever designed but I digress. Can anyone help?
Welcome to Beoworld! Several options will move you in the right direction: Use a Range Reducer - see here:
Thats a tough one. The BS9000 (and maybe the BS2500) can probably be set to option 4 where it only accept commands when Link is pressed before the command. Also if acceptable some units could be set to option 0 where they do not react to the remote and therefor only have local control. Another option is  a plastic cower (I dont know what the real naming gor it is) to reduce the IR signal strenght of the BEO4
Thanks Guy. Appreciate the response! A range reducer is interesting. The option buttons are a little cumbersome. What about later remotes? Anyway to program devices individually or is that problematic due to when they were designed? Obviously, electronics have evolved over time. Thoughts? Or, is this just not possible? Again, thanks on the range limiter suggestion. I will investigate this.
I’d say….if you want a convenient solution, you can have 2 devices controlled. As already noted, one must be in Option 4 (means pushing the Link butoon before the actual sorce button. All other devices must be in Option 0 and will then have to be contolled manually on the device. This ‘problem’ has been solved with the newer devices and the Beoremote One/bt, as each device can be adressed individually from one remote. MM
Just to complete the list: a MasterLink Gateway is also an option (if...)
