Option headphones is missing on BR1
Got my Theatre installed (+LG) and wanted to connect my H7. On B&O support (FAQ) there is an instruction on how to do that. They show the option ‘headphones on’ on the BR1. But that option is not on my remote. Can’t find how to add option.
I can connect the H7 to the LG but get no sound when setting Sound Out to bluetooth?
Ive seen two pairing modes on the Theatre.
On H9's ,it seems to be handled via the Theatre. I think if your H7's are in the BeoApp, this should show on the List >> Headphones on/off
On the Portals, the pairing was via the LG pairing system - which was irritating because if the Mrs was watching TV and I was on my iPad, the LG/Portal would take over the TV sound. I unpaired that connection quickly.
Thank you for your prompt reply. Of course the H7 is in the app (as all my other B&O stuff). But checked again, turned on the H7. TV connected immediately and switched of the speakers. But no sound in the H7
