I have tried to test if it works, and the only 2 way compatible B&O I have is MCL2 components. So I have tried it with a MCL2AV both with local sources connected, and connected to a BC9300 via MCL.
Everything seems to work, and I get the track numbers when playing a CD, so two way is also working.
However the display on the MCP 6500 seems to turn of within 10 seconds of use. Is this normal behaviour?
If so can the time for display blanking be adjusted?
I understand the reasoning for blanking the display after some time to save battery, but the 2 way feature is less impressive then.
