Beosound 8 / Beoplay A8 remote - quick questions
Just a couple of quick questions about these little round remotes, if anyone knows:
  • Are the remotes for the Beosound 8 and Beoplay A8 the same?  They look the same
  • I'm assuming these remotes will only control those two models, and will not control other B&O devices - am I right in that?
That's odd, why is it doing that?
Since the round remote is IR and both devices can be controlled by a Beo 4, I would assume that the remote uses usual B&O IR commands.
Therefor both remotes would be the same and allow at least volume control to Audio devices.
I've ended up with one of these remotes in a package of B&O stuff, which is why I ask.  I don't have a Beosound 8 or Beoplay A8 and have no intention of buying one, but it's a nice little remote, and if it would have controlled my other equipment, I would have kept it.
However when I test it, it does not control my Beosound 4.
Since I added the original post I have done the 'phone camera test' to check that the IR LED is blinking when a button is pressed, and it is, so I would have to assume that it is working, but it does not send the same signals as a Beo4.
Shame, but not a major issue for me, I'll just sell it on eBay.  Thanks for your help.
Just for info - since posting this yesterday I found
There is a little info in this older thread, but it does not seems to be conclusive /forum/general-discussion-and-questions/beoplay-a8-remote---control-other-bampo-products . There is mentioning of the A.aux command, but since you can not activate your BS4 with it it must have some difference in the remote codes
