Beoremote One BT Sony TV Pairing
Hello,
Just bought a Beoremote One BT that I am trying to pair using BT to a Sony Bravia TV (KD-65X9000E) , set remote for pairing, and TV into Bluetooth pairing mode, TV says searching for accessories, and nothing comes up - any idea how to fix this??
Beosystem 5000, Beosound 9000, Beolab 8000, Beovision 11-46, Beovision 5-40, Beoplay A9, Beosound 8, Beosound 2 (MP3), Beosound Level, Beosound Balance, Beolit 15, Beoremote One BT, Beoremote Halo, Beo6 remote, Beosound Essence, Beoplay A1, Beoplay P2, Beoplay A2
I wasn't aware that the BeoRemote was Sony compatible.
The only TV that out of the box (and after installing an app on the TV) work are the LG Oled screens.
I might be wrong but I don't think that your TV will work with the remote... Kinda like saying you downloaded the latest Apple OS and want to install it on your Windows PC.
Karel.
I agree with Karel, I think Sony TV are not compatible with B&O remote(s), even the BT one.
P. S. : Hey Karel, are you still satisfied with your BV 14 and your Balance?
Why do you think this will work?
beoremote one bt si for b&o tv and LG (only with
stage,eclipse,harmony,theatre) because the beoremote one comunicate with the beopart that with hdmi and lan comunicate with LG screen
Thanks everyone for your update, for some reason I had thought Beoremote One BT will work with Sony the same way as LG.
In any case, I have paired with my Apple TV using BT for now - only issue is when changing products to another BT connection such as Beoplay A9, I have to reconnect the Apple TV again by going into the Apple TV bluetooth menu, any way of reconnecting the remote to Apple TV without doing that?
