Beoremote one BT and Lutron for b&O
Hi All, I have a previous IR version of the BR1 that controls Lutron for B&O I have now purchased a theatre and want to use the BR1 with BT and IR to control it as at present I am using two controllers. It seems this is not an easy taste though without skipping in and out of menus,  can this be done with one of the four  shortcut buttons   All help most welcome!
You can use the BR1 in ir mode or Bluetooth, not both. There is a work around but you need to press a million buttons. The only sollution I see is getting a BLI with interface for lutron, but it will be very expensive. I bought this https://www.google.nl/url?sa=i&url=https%3A%2F%2Fwww.lutron.com%2FTechnicalDocumentLibrary%2Fgrx-ci-rs232.pdf&psig=AOvVaw3pK8_8n39YWsWKwZj3p_Tr&ust=1676501014132000&source=images&cd=vfe&ved=0CBAQjhxqFwoTCJCO5YuLlv0CFQAAAAAdAAAAABAE but I already had a BLI. You can also use an essence remote in IR mode still 2 remotes but it looks nice on the coffeetable.
