Hi all,
Finally got a new house, and have combined a mix of old & new products successfully into multiroom, controlled by the iPhone B&O app:
- Two Beoplay V1
- Beoplay M5
- Beoplay M3
Currently use the B&O app, and two Beo4 remotes with nav button for the TVs (and use of the Join button). but I'd like to get away from the app for day-to-day operation and use a Beoremote One (BR1) instead, and am wondering how smoothly this works.
Let's say I want to sit down in from of the V1 TV (an IR-only device) and fire up and listen to a particular
B&O Radio station, likely off my M5. Could I do this all strictly from the BR1, and how cumbersome would it be? I'm guessing it'd go something like this:
- Select the M5 on the remote, then scroll to a "favorite"d source,
- Select the TV on the remote, then select "join" under the List button.
Would it be that simple? Thanks for any thoughts on this!
-- beopaul
