Beo4 "special remote "
Hoping someone can help me. My Beovision 7-40 used to play Region 4 DVD's, but it won't now. Some time ago Keith posted instructions on how to make the TV region free. But it requires a "Special Beo4 remote". Where can I buy one , or is it a "dealer only tool" regards Noel.
I believe I have one somewhere in one of my many boxes which have recently landed in SE Asia. I think I have instructions somewhere too. I will post these later/tomorrow to see if they are of any help? Otherwise open to discussion. rgds 10%
  Hi,10% Thanks for the speedy reply.     How much do you want  for it - and where are you located ? ( To get a shipping quote) regards Noel.
Hi Noel, Attached are old instructions. Please give me the weekend to find and see if the remote still powers up (I cant test it on anything anymore). Please PM me.
Hello again 10%, Thanks for sending the instructions-much appreciated, regards Noel.
Alternatively, the IR codes of this region free command can be incorporated in the Beo5/6 remotes.
Sorry griebel- I don't quite understand. regards Noel.
Hi Keith, Thanks for the info-much appreciated. Unfortunately, my budget doesn't extend to purchase of Beo5. ( I could possibly buy another Beovision 7-40 for not much more ) May I take this opportunity to wish you well in your "retirement", and express my gratitude for your support over the years, regards Noel.
Search the forum. This has been discussed very recently on here. ? Stoobie
Exeter, Devon, UK
