The remote is the one with V Tape, Record, A Tape, and the AV button.
Where I'm at right now is: volume up doesn't work(even though I can see the IR led firing through my phone camera), and when I go to the menu on the TV, the Go button doesn't work(can see the IR firing).
If I open menu I can hit 7 to get to the External Sources, but I can't make any changes(and I can't get my component input to work)
I have read that I may need to change the mode on the remote. If I hit standby+list I get only 3 options: Add? Option? Remove? All of the documentation seems to say there is supposed to be a Config? option as well.
Hitting go in Option gives me: V. Opt, A. Opt, and L. Opt. I can't hit go on any of these, so I have tried 0, 1, 2, 3, etc as different control inputs after selecting V. Opt.
None of these change anything.
Do I just have a bad remote? Should I buy a newer version? Will a newer version(example one with DVD button) work with my TV?
This TV looks amazing from what tiny little bit I can get working on it..... but so far it is just requiring black magic to get it to work.
