Beo4 Change function of button
Can I change the function of the A.MEM button on my Beo4? I’m using the AUX line to stream music via an Airport Express and I’m choosing AUX from the list button on Beo4. Is it possible to change the function on A.MEM so that when pressing it, I choose AUX?
Thanks. I’m using a Beomaster5/Beosound5 system.
@Fisp Do you know that you can move/reorder the entries in the List (that is, if your Beo4 supports that). Moving A.Aux to the first place there would make things easier. MM
Yes, that is what I’m doing now. I wanted to go directly to AUX via a button, but that does not seem to be possible. I have the Beoremote6, though, and here I have an AUX “button”.
The A.TERMINAL from 1987 would have done the job!
