Beo4 and beolink converter 1611
Hello, I purchased a beolink converter 1611 to use it with my beolab 3500. How do I get the beo4 to communicate with the converter? and after that with to ajust the sound settings on the beolab? I read different manuals (masterlink handbook, beolink handbook, converter manual) but a bit difficult to understand, I have to programm the beo4?
If I understand your question right….. You don’t! The 1611 was created to convert the old MCL system to the (then) newer ML system. The BL3500 is a dedicated link speaker that needs a master (audio or video) to be used. If setup right, you can draw on the sources from e.g. an audiomaster/the sources there (radio/cd……). You control the BL3500 with the remote - have a look here: https://www.beoworld.org/prod_details.asp?pid=373 MM
Hi, beolink converter 1611 can act as a audiomaster so you only connect source to it and masterlink between converter and bl3500 and press cd or radio doesnt matter and it should work
Sure - but you’ll need to activate and control the 3500 to get sound. The 1611 can be hidden away once the connection is done. MM
Hi, yes of cource ts need the beo4 to the beolab 3500 but i maybe missunderstand ts
