Alternative source selection on Halo - BLI combination
Alternative for choosing sources on a Halo by using one Button and the Wheel_turned. Select device by turning the wheel anti-clockwise Select the source by turning the wheel clockwise Press twice the button to select/confirm the selection. Two macros are needed; one for the event “Wheel_turned” the other for “Button_pressed” for the same Halo button. The matrices in both Macros must exactly the same.
  • Macro 1.
Event: Wheel_turned for a Halo Button (with “your_Halo_button_IDnumber”) function(event, engine) local Ea=event.area() local Ez=event.zone() --Resource selectButton as String local selectButton_query = engine.query(Ea.."/"..Ez.."/VARIABLE/selectButton") local sButton = selectButton_query[1].get_string("VALUE") --Resource SourceNo as Integer local source_query=engine.query(Ea.."/"..Ez.."/VARIABLE/SourceNo") local sourceNr = source_query[1].get_number("VALUE") if sourceNr==nil then sourceNr=1 end local device_query=engine.query("Upstairs/Study/VARIABLE/DeviceNo") local deviceNr = device_query[1].get_number("VALUE") if deviceNr==nil then deviceNr=1 end if deviceNr==0 then deviceNr=1 end local haloName=“you”r_Halo_name_as_string local haloID=“your_Halo_button_IDnumber_as_string” local direction local device local deviceName local deviceMax=5 --set to number of devices programmed local source local sourceMax=14 --set to number of sources programmed local sourceName local sourceID local info local bs9000cd local a={i=sourceMax, j=4} local b={x=deviceMax, y=4} --{"Halo source name", source, origin, x} below are examples change to your system a[0]={"exit","exit","",0} a[1]={"A6 Music","MUSIC", "255aaaaa”,0} a[2]={"A6 TuneIN","TUNEIN", "255aaaaa”,0} a[3]={"BS3000 cd","CD", "240bbbbb”,0} a[4]={"Beogram 4000","LINE IN", "240bbbbb",0} a[5]={"BS7000 cd","CD", "272ccccc"} a[6]={"BS7000 ph","NET RADIO", "272ccccc",0} a[7]={"BeoCenter2cd","CD", "231ddddd",0} a[8]={"BS9000-cd1","CD", "238eeeee",1} a[9]={"BS9000-cd2","CD", "238eeeee",2} a[10]={"BS9000-cd3","CD", "238eeeee",3} a[11]={"BS9000-cd4","CD", "238eeeee",4} a[12]={"BS9000-cd5","CD", "238eeeee",5} a[13]={"BS9000-cd6","CD", "238eeeee",6} a[14]={"BS5 Encore","LINE IN", "238eeeee",0} -- x = cd nummer in case of BS9000 (BLC must be set as ASlave); --{"Device Name", Name on Halo, Area, Zone} note: device areas and device zones are as defined in the BLI b[1]={"BeoPlay A6", "BeoPlay A6”,”your_device_Area”, ”your_device_Zone”} b[2]={"BeoSound 35", "BeoSound 35","your_device_Area","your_device_Zone"} b[3]={"BS Essence - Bath", "BS Essence Bath","your_device_Area","your_device_Zone"} b[4]={"BS Essence - Bed", "BS Essence Bed","your_device_Area","your_device_Zone"} b[5]={"BeoSound Shape", "BS Shape","your_device_Area","your_device_Zone"}   if event.parameters()["OFFSET"] then if tonumber(event.parameters()["OFFSET"])>=1 then direction= true else direction=false end if direction then sourceNr = sourceNr + 1 if sourceNr==sourceMax+1 then sourceNr=0 end if sourceNr==0 then sourceName=a[sourceNr][1] engine.fire(Ea.."/"..Ez.."/VARIABLE/selectButton/SET?VALUE=exitS") else engine.fire(Ea.."/"..Ez.."/VARIABLE/selectButton/SET?VALUE=startS") sourceName=a[sourceNr][1] source=a[sourceNr][2] sourceID=a[sourceNr][3] end info=b[deviceNr][2] engine.fire(Ea.."/"..Ez.."/VARIABLE/SourceNo/SET?VALUE="..tostring(sourceNr)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_TITLE?BUTTON="..haloID.."&TITLE="..tostring(sourceName)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_SUBTITLE?BUTTON="..haloID.."&SUBTITLE="..tostring(info)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_WHEEL_VALUE?BUTTON="..haloID.."&VALUE="..tostring(math.floor(sourceNr*100/sourceMax))) else deviceNr = deviceNr + 1 if deviceNr==deviceMax+1 then deviceNr=1 end device=b[deviceNr][1] deviceName=b[deviceNr][2] info=a[sourceNr][1] engine.fire(Ea.."/"..Ez.."/VARIABLE/DeviceNo/SET?VALUE="..tostring(deviceNr)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_TITLE?BUTTON="..haloID.."&TITLE="..tostring(deviceName)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_SUBTITLE?BUTTON="..haloID.."&SUBTITLE="..tostring(info)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_WHEEL_VALUE?BUTTON="..haloID.."&VALUE="..tostring(math.floor(deviceNr*100/deviceMax))) end end end
  • Macro 2
Event: Button_pressed for the same Halo Button function(event, engine) local Ea=event.area() local Ez=event.zone() --Resource selectButton as String local selectButton_query = engine.query(Ea.."/"..Ez.."/VARIABLE/selectButton") local sButton = selectButton_query[1].get_string("VALUE") --Resource SourceNo as Integer local sourcenr_query=engine.query(Ea.."/"..Ez.."/VARIABLE/SourceNo") local sourceNr = sourcenr_query[1].get_number("VALUE") if sourceNr==nil then sourceNr=1 end local devicenr_query=engine.query("Upstairs/Study/VARIABLE/DeviceNo") local deviceNr = devicenr_query[1].get_number("VALUE") if deviceNr==nil then deviceNr=1 end if deviceNr==0 then deviceNr=1 end local device local deviceName local Da local Dz local source local sourceMax=14 --set to number of sources programmed local deviceMax=5. --set to number of devices programmed local sourceName local info local bs9000cd local a={i=sourceMax, j=4} local b={x=deviceMax, y=4} local haloName=“you”r_Halo_name_as_string local haloID=“your_Halo_button_IDnumber_as_string” local tst --{"Halo source name", source, origin, x} below are examples change to your system a[0]={"exit","exit","",0} a[1]={"A6 Music","MUSIC", "255aaaaa”,0} a[2]={"A6 TuneIN","TUNEIN", "255aaaaa”,0} a[3]={"BS3000 cd","CD", "240bbbbb”,0} a[4]={"Beogram 4000","LINE IN", "240bbbbb",0} a[5]={"BS7000 cd","CD", "272ccccc"} a[6]={"BS7000 ph","NET RADIO", "272ccccc",0} a[7]={"BeoCenter2cd","CD", "231ddddd",0} a[8]={"BS9000-cd1","CD", "238eeeee",1} a[9]={"BS9000-cd2","CD", "238eeeee",2} a[10]={"BS9000-cd3","CD", "238eeeee",3} a[11]={"BS9000-cd4","CD", "238eeeee",4} a[12]={"BS9000-cd5","CD", "238eeeee",5} a[13]={"BS9000-cd6","CD", "238eeeee",6} a[14]={"BS5 Encore","LINE IN", "238eeeee",0} -- x = cd nummer in case of BS9000 (BLC must be set as ASlave); --{"Device Name", Name on Halo, Area, Zone} note: device areas and device zones are as defined in the BLI b[1]={"BeoPlay A6", "BeoPlay A6”,”your_device_Area”, ”your_device_Zone”} b[2]={"BeoSound 35", "BeoSound 35","your_device_Area","your_device_Zone"} b[3]={"BS Essence - Bath", "BS Essence Bath","your_device_Area","your_device_Zone"} b[4]={"BS Essence - Bed", "BS Essence Bed","your_device_Area","your_device_Zone"} b[5]={"BeoSound Shape", "BS Shape","your_device_Area","your_device_Zone"} if sButton=="exitS" then goto exit else if sButton=="playS" then Da=b[deviceNr][3] Dz=b[deviceNr][4] device=b[deviceNr][1] deviceName=b[deviceNr][2] sourceID=a[sourceNr][3] source=a[sourceNr][2] nr=a[sourceNr][4] bs9000cd=sourceID..source -- ID Cd of BS9000 tst=Da.."/"..Dz.."/AV renderer/"..device.."/Select source?Connector=&Origin="..sourceID.."&Source Type="..source engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_TITLE?BUTTON="..haloID.."&TITLE="..tostring(deviceName)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_SUBTITLE?BUTTON="..haloID.."&SUBTITLE="..tostring(source)) engine.fire(tst) - the “origin” of the BS9000 BLC must be set in line below correctly (note BLC programmed as ASlave) if bs9000cd=="238eeeeeCD” then engine.fire("*/*/AV renderer/BS9000 BLC/Send digit?Digit="..tostring(nr)) end sButton="exitS" else deviceName=b[deviceNr][2] sourceName=a[sourceNr][1] engine.fire(Ea.."/"..Ez.."/VARIABLE/selectButton/SET?VALUE=playS") engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_TITLE?BUTTON="..haloID.."&TITLE="..tostring(deviceName)) engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_SUBTITLE?BUTTON="..haloID.."&SUBTITLE="..tostring(sourceName)) end end ::exit:: if sButton=="exitS" then sourceName="B&o Sources" engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_TITLE?BUTTON="..haloID.."&TITLE="..tostring(sourceName)) info="Turn to Select" engine.fire(Ea.."/"..Ez.."/Halo remote/"..haloName.."/SET_SUBTITLE?BUTTON="..haloID.."&SUBTITLE="..tostring(info)) engine.fire(Ea.."/"..Ez.."/VARIABLE/selectButton/SET?VALUE=startS") end end
for the interested......... I got similar Macros for Link/Join devices and for setting devices to Standby. Let it know and I will make them accessible.
Amazing stuff Carolpa! Damn I had to postpone BLI acquisition for couple of months, so envious about all cool things you can do with the Halo now. :) Mine still in cupboard waiting for the installation. :/
Trying to find more info on macros. I had no idea it was programmable. Would someone please direct me to more info on this?
you need:
  1. Beoliving blackbox + sw upgrade to Pro (see website of Khimo)
  2. Halo (of course)
this will open doors to extended home automation
